Viali93
Newbie
Message 1 of 4
Mac doesn’t connect to Hub4
It does, then it stops working. It basically says “BTHub4 is turned on but not connected to a network”... Help pls!
Tags (1)
3 REPLIES 3
Viali93
Newbie
Message 2 of 4
Re: Mac doesn’t connect to Hub4
And now it says that BTHub does not have an IP address, which is why it can’t connect
Message 3 of 4
Welcome to this user forum.
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
Viali93
Newbie
Message 4 of 4
Hi Keith,
Thanks for replying but that that didn’t do anything for my Mac. 😞
To clarify, the wifi works fine on my other divices. It’s just my Mac acting up.
So the status on my Network is now:
“BTHub4 does not have an IP address and cannot connect to the Internet”.
Is there a way I can write the Hub’s IP address manually?
