GavsBags
Newbie
Message 1 of 2
MacBook Air Intermittently Dropping Off WiFi to Home Hub 4
Our MacBook Air worked like a dream with our Home Hub 4 for many months.  Then all of a sudden it intermittenly won't connect.  All other devices - iPad2, PC's, Mobiles, Kindles - connect fine.  Also, the Mac will connect fine to a work router I have in the house but the signal from that is weak in most of the house.
Mostly the problem is solved by refreshing the iFi channel but thats a right pain all the time.  Sometimes the problem solved by rebooting the machine or the router.......theres got to be a simple solution to this surely? Its driving me mad!!
1 REPLY 1
Message 2 of 2
Re: MacBook Air Intermittently Dropping Off WiFi to Home Hub 4
Reset the hub to factory default, then
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
Devices where there are known to be problems include:
    • Some Apple devices including iPhone 5 and Apple TV
    • some Android smartphones
    • Xbox<
