casslm
Message 11 of 46
Re: Macs drop off and won't connect to BTHub - Macs and BT Broadband
I have a possibly related problem.
Two iMacs and a Windows 7 laptop, HomeHub 5.
I have the main iMac on a cable, the other and the laptop via WiFi.
The laptop can print to the cable iMac's printer but the second iMac cannot see the first iMac on the network - no shared driver or printers.
If I unplug the LAB cable and make the main iMac use WiFi, then the second iMac immediately sees it and can print.
So there seems to be something wrong with how the wired connections are implemented on the HomeHub5.
I've also had no end of hassle trying to get the wired iMac to see a NAS drive (had similar problems with HH3 too).  I want this to be a wired connection because it makes big backups much faster than via WiFi but frequently the iMac cannot find its TimeMachine files on the NAS drive and even when it can (after lots of hopeful rebooting, restarting the router, restarting the drive, running discovery tools etc) it tends to drop the drive again shortly after doing its backup.
If I run the HH5 cable into an old spare Linksys router (or a 4-port hub) and use it to feed both the iMac and the drive then there is no problem at all (apart from wasting electricity).  BT says this is a drive problem and Seagate say it is a router problem!
Does anyone know of a replacement for the HomeHub5 that actually works?
Roger
Message 12 of 46
Roger
Yes, the TP LINK TD-W9980. About £65 in the BT shop, going like hotcakes apparently.
Message 13 of 46
After a few days of pulling my hair out I cam across this solution - worked straight away - thank you.
Captive
Newbie
Message 14 of 46
Thanks for sharing this. I've struggled with this problem for ages and now all seems to be fine. Brilliant! Cheers.
Intertav
Newbie
Message 15 of 46
This is brilliant and works without a hitch. i have been looking for a solution to my WIFI issues for 3 months and numerous calls with Apple. Thank you for this....I can finally sleep peacefully
Careyk
Newbie
Message 16 of 46
Thank you so much for posting this simple guide! We have been tortured for months with this issue and the apple store technical team have been NO help whatsoever. They advised a hard reboot for the mac! My husband is over the moon with me and I'm just so grateful someone took the time to post a solution. 😄
jfkyachts
Message 17 of 46
Do we lose any speed or functions as a result of doing this? Just wondering?
Does this affect IPads or earlier Macs....?
I have just carried out the instructions so will report back!
airbourneuk
Message 18 of 46
Thanks for this post. Was having same problem and your solution resolved it.
Swanny1
Newbie
Message 19 of 46
Brilliant fix!  Thanks so much for posting - brilliant solution to an intractable and very frustrating problem!
jfkyachts
Message 20 of 46
Three days after switching off the 5Mhz wireless, it does seem to be working much much better - something clearly happened around April 25th when BT again "updated" the hub. Really annoying.
I am still waiting/wondering if anything follows this - like reduced functionality in other areas, but our Broadband speed in Susses is so slow, it is difficult to tell!
Any other comments will be most welcome to hear - further experiences.
