My phone and router are currently connected to a phone socket in my dining room, I really want to move these in to the hallway. The issue I have is that the master socket is in the hallway, with a wire that comes out and goes into the dining room. The master socket does not work if I plug a phone into it. What do I need to do to get rid of the extension and get the master socker working again?
Welcome to this user forum.
Are you a BT Broadband customer?
if your 'master socket' does not work when you connect a phone then it is not your master socket have you openrec socket up to trace wiring?
you can always use local paper to get telecom engineer
