Newbie
Message 1 of 4
Master Socket - Extension
My phone and router are currently connected to a phone socket in my dining room, I really want to move these in to the hallway.  The issue I have is that the master socket is in the hallway, with a wire that comes out and goes into the dining room.  The master socket does not work if I plug a phone into it.  What do I need to do to get rid of the extension and get the master socker working again?
3 REPLIES 3
Message 2 of 4
Re: Master Socket - Extension
Welcome to this user forum.
Are you a BT Broadband customer?
Message 3 of 4
if your 'master socket' does not work when you connect a phone then it is not your master socket  have you openrec socket up to trace wiring?
you can always use local paper to get telecom engineer
Distinguished Guru
Message 4 of 4
Can you post a photo of what you think is the master socket?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
