Liam_
Expert
Message 11 of 20
Re: Master Socket Query
@MattTing
If you are still having issues connecting try this. ( If using a static IP on PC set it to dynamic to connect to the modem on 192.168.2.1   It will let you know that the modem is working properly and the issue is with the router config).
Connect modem to phone socket as you normally would, connect PC to modem with ethernet cable.  Open Network and Sharing Centre in Windows.
Select Setup a new Connection or Network.
Select Connect to the Internet, click next.
You will see Broadband PPoE,  click that and enter user name and password from earlier post.
Click Connect.  Your PC should now have access to the Internet.
Didn't have any problems here, tested the modem by doing the above and once it proved to be working, reconfigured the router (a FritzBox 3390) to connect to an external modem and that was it.
Need to go out for an hour or so, I'll check the post when I get back.
MattTing
Message 12 of 20
I've progressed. Now have the Router set up, but getting an error page from bt in my browser
62.6.38.125/index
"SERVICE INFORMATION
You have been connected.."
I'm now a bit stuck again. More advice appreciated!
Liam_
Expert
Message 13 of 20
That's a good one, the usual account problems like not provisioned yet obviously don't apply.  I suspect it's the router configuration is wrong.  You did use the username and password mentioned before?
MattTing
Message 14 of 20
Think I may have missed that step, I was so delighted at getting to first base!
Liam_
Expert
Message 15 of 20
Wouldn't be the first time I forgot to put in something.  Stuff happens.
MattTing
Message 16 of 20
Think it might be sorted. Router is upgrading firmware which I take as a good sign..
Liam_
Expert
Message 17 of 20
Well it seems to indicate you have a connection to the Internet.  So looking good.
MattTing
Message 18 of 20
Thanks.  all sorted now - whooshy fast broadband all over the house!
just confirms that there is no such thing as plug and play..
Message 19 of 20
Having to only enter user name and password is about as close as you are going to get. Smiley Happy
Liam_
Expert
Message 20 of 20
Indeed.  Glad you got it all working, I think you'll be happy with that kit.
