Message 1 of 3
Mesh recommendations?
Fibre 500 with EE Smart Hub installed 11/24.
My requirement is to use  a mesh, where  one box will be wired to a 8 way switch in my studio/office feeding existing PCs and Printers.
EERO 6 has been suggested but my understanding is that  I would either connect EE router to the EERO 6 router but the mesh(s) has no ports to feed the switch, and of course phone.
For clarification,  I am currently  running copper from my TTbus line to the office switch. YES I currently  have two BBs, EE500 and TT copper.
Looking for recommendations and first hand advice so that I can eventually lose the TTbus line but port phone number to Digital Voice.
David
2 REPLIES 2
Message 2 of 3
Re: Mesh recommendations?
@DigitalDave
Look at the TP Link Deco range, each has two Ethernet ports.
https://www.tp-link.com/uk/home-networking/deco/
I use a five port switch on one of my Deco ports, and it works just fine.
Message 3 of 3
Thanks Keith.
Checking them out now.
