Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Our new microwave oven is causing interference that affects my PC and phones as they are around 2 metres in bedroom directly above microwave in kitchen.
I'm addressing that with the manufacturers as no previous unit has had this impact.
Why aren't my phone and PC switching to the 5Ghz signal from the smart hub 2 if the 2.4 Ghz signal is lost?
Are there any tweaks I should do to the smart hub2 or just go back to the old HH6 and manually use the 5Ghz signal?
have you tried changing the channel for the 2.4ghz network
if you want to force the 5ghz then just turn off the 2.4ghz network in the hub
Its your phone and PC which decide what band to use not the Hub.
Microwave ovens are increasing in power now. Hence the stray radiation increases.
From past and current experience, disable the 2.4 GHz on your hub. If you are only using the microwave for a few minutes, then don’t use devices while microwave is in use. It’s much simpler than setting up during that microwave duration. It shouldn’t affect your landline telephone.......
This shows itself if you have a kitchen tv, where you have a wireless transmitter from the main tv. You have to buy a 5Ghz transmitter and align very carefully...
Ask the manufacturer of those devices.
As already posted it is the devices that should be changing from 2.4 to the 5ghz network the hub is broadcasting both 2.4/5ghz but it is not up to the hub to decide which network a device connects that is up to the device. The principle is the same for the hh6
So I need to switch off the 2.4 Ghz hub signal and get the PC & iphone to connect to the 5 Ghz BSSID? I thought the SH2 SSID was broadcasting both BSSIDs out and the devices could pick either when one signal died off.
As the 2.4 Ghz BSSID is strongest in the room then I take it that's all they have ever associated to, since the SH2 was installed?
