Message 1 of 2
Minecraft adding it's own port forwards?
The kids play minecraft on their switches and xbox, but it seems to be adding loads of it's own port forwards on the firewall. Guessing this is upnp at play but was surprised to see so many - currently 120.
Does anyone please have any idea how to prevent this?
Kids are 6 and 7, so no way they'd have a clue how to add these manually themselves.
1 REPLY 1
Message 2 of 2
Re: Minecraft adding it's own port forwards?
@KevinF83
Disable UPnP on the home hub.
You may have to factory reset the home hub first, then disable UPnP right away before Minecraft is started.
You may get some complaints about Minecraft not working properly in a multiplayer game.
