Newbie
Message 1 of 3
Mini Discs x 3 set-up
I’ve just purchased the 3 mini discs to help my poor Wi-fi across the house, all seemed to be set up showing blue lights but once I move them 3 metres away from my hub, the light turns red.  Anyone else had a similar problem, I’ve even moved my hub to my hallway to see if that helped but no.  I’ve spent hours now trying to set up and totally frustrated.
2 REPLIES 2
Recognised Expert
Message 2 of 3
Re: Mini Discs x 3 set-up
Are you keeping one disc connected to the HUB with an Ethernet cable?
All Whole home discs have to have one disc connected this way.
Also are you using the APP to install them?
Newbie
Message 3 of 3
Hi thanks for the reply, it wasn’t clear that the first one would need to be connected at all times to the Hub, I have it working now thank you.
