Newbie
Message 1 of 2
Mini wifi home hotspot connection issues
When connecting to the hotspot, I can connect for a short period then the connection becomes limited and the link light turns off.When investigating further it states that the "wifi" doesn't have a valid IP configuration. My PS4 when trying to connect also says it cannot obtain an IP address. However this is not a constant thing, and it can go for a number of hours working perfectly fine.
Cheers for your help
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Mini wifi home hotspot connection issues
Hi @Cwood4321 and welcome.
Can you confirm which home hotspot you're using? Is it the 500? If so you'll find help with that here. For the 600 you'll find help here.
Cheers
David
