starship
Message 1 of 2
Mix and match BT Mini Home Hotspot 600 Multi Kit
I puchased a bt mini home hotspot kit consisting of the two plug in kit, having found these worked so well and wanted to gain connection to my workshop,so i purchased the treble kit. All work great until the main extender that plugs into the home hub via ethernet failed, So i was wondering if i am able to mix & matched with the main extender from the double kit with the triple kit.
1 REPLY 1
Message 2 of 2
Re: Mix and match BT Mini Home Hotspot 600 Multi Kit
Yes, you can
