richlatham
Message 1 of 2
Mixing Comtrend 9020 with BT Vision Powerline adaptors
I'm using a pair of Comtrend 9020 adaptors for my PC and have received 2 BT Vision Powerline adaptors with my BT Youview box today. I've tried mixing them but don't seem to be able to get them to link. Is there any way that I can use 2 of one make for my PC and one of the other make for the Youview box or vice versa
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Mixing Comtrend 9020 with BT Vision Powerline adaptors
Hi Richlatham,
Thanks for posting. They need to be the same make. There is a thread discussing the same issue here .
Hope that helps.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
