davidw87
Message 1 of 22
Mk3 Openreach socket as an extension of master socket?
Hi
I recently moved to a 1980s house which has a (functional) master socket near the front room door. On the other side of the room is a Mk3 Openreach socket which is wired, with a partially-concealed cable around the edge of the room, into the original master socket.
Currently I've got my router plugged into the Mk3 socket and it seems fine and the expected speed, but is this the correct setup? Should the router be plugged into the master socket (with filter of course)? If so, should the Mk3 socket be removed as it won't be required and is unnecessarily hard-wired into the master socket?
Thanks.
21 REPLIES 21
Message 2 of 22
Re: Mk3 Openreach socket as an extension of master socket?
it will depend on how the extension is wired as it could be ok if wired as a data extension just for the router
davidw87
Message 3 of 22
Thanks - do you know how I could tell if it's just a data extension?
The Mk3 socket, with its built-in filter, works with both phone and broadband so seems to be for more than just a router (but maybe whoever installed it wasn't intending on actually using it for phone as well?).
Message 4 of 22
does the original master work?  is the mk3 wired as an extension probably to front of original master
if it works ok and speed fine then I would just leave it unless you want it moved/removed
Techwizz
Message 5 of 22
AFAIK, the data extension will have just one RJ-45 port (not RJ-11 which is used for telephony) on the faceplate.
Message 6 of 22
@Techwizz
it will depend on who wired up the extension and in this case it does not appear to have been openreach as they would not put 2 master sockets on one conenction
davidw87
Message 7 of 22
Yes the original master works. The Mk3 wire seems to enter the bottom of the master, as does another extension wire which goes into the dining room.
My Home Hub has been playing up (randomly rebooting and wifi not working properly) so I replaced it with a TP-Link at the weekend. Works fine so far, although DSL dropped and reconnected at 5am today according to logs.
I may plug the router straight into the original master, with a filter.
See below an image of the setup (using photos I found online as I'm not home at the moment). The arrows denote the cables!
Thanks.
Message 8 of 22
I would be switching the mk3 and the old master making the mk3 first socket and any extensions then wired back to the front of the mk3 master  router then conencted to mk3
Message 9 of 22
The early morning disconnect would be due to DLM making changes to the line profile. It usually happens between 2-5 AM, I have seen it on my daughter`s TP Link router, but it does not happen on my ADSL connection.
davidw87
Message 10 of 22
Thanks all for the info - I may leave it for now and see how it goes, with the option of doing what @imjolly suggests above.
The DLM change makes sense as I noticed the line speed increased from about 50 to 55Mbps. Worth noting that the Home Hub only managed a max of 45Mbps!
