Message 1 of 9
Mobile Phone not connecting to WiFi
I have had the same bt homehub for several years and I have had my mobile phone for several months.
The last 2 days my phone will not connect to my by WiFi despite me re-entering the password. All other devices have maintained connection.
When I try and connect it says connecting and then changes to saved. I can connect to bt WiFi but not my specific WiFi and therefore I can no longer control the lights in my home using the phone.
8 REPLIES 8
Message 2 of 9
Re: Mobile Phone not connecting to WiFi
Have you tried restarting your mobile?
Message 3 of 9
I'm afraid that hasn't fixed the problem.
Message 4 of 9
Have you added any new devices to your wifi network recently
Message 5 of 9
@Helenwilce
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn off smart setup.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
The hub`s internal connection table can get full, and the only way to clear it, is with a factory reset.
Message 6 of 9
I contacted my phone manufacturers helpline at the same time and they have resolved my problem. Thanks for your input though
Moderator
Moderator
Message 7 of 9
Hi @Helenwilce I'm glad you got it sorted, are you able to share the solution with the community as it may help others who are experiencing the same issue?
Message 8 of 9
I ended up having a chat with a guy at Google as my phone is a Google pixel, I explained that I had tried re-entering the password on my phone after forgetting the original details.
He appeared to be able to access my phone remotely and could follow what I was doing. He instructed me to forget and re-enter the password again and this time it connected.
I don't know if he was bug fixing his end without me knowing about it so I would recommend having them on the line while you reattempt things you may have already tried
Moderator
Moderator
Message 9 of 9
Hi @Helenwilce many thanks for sharing that, it may help others experiencing the same issue. Cheers
