1pipster
Message 1 of 4
Mobile no longer connecting to Home Hub 5 after setting up new Windows 10 Laptop
Hi, bit of an odd problem.
I set up a new Windows 10 Laptop last week, connected fine to my Home Hub 5, but since then my Windows 10 mobile phone no longer connects to the Home Hub. All other devices in the house still work.
The hub is set up with the two  bandwidths separated, all devices are connected to the 2.4 GHz band.
Many thanks in advance for any suggestions.
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: Mobile no longer connecting to Home Hub 5 after setting up new Windows 10 Laptop
Welcome to this user forum.
Its most likely a home hub  "feature".
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs again.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
1pipster
Message 3 of 4
Thank you, will try that.
1pipster
Message 4 of 4
Many thanks again - all reset and working.
