Message 1 of 3
Modem Mode - Smart Hub 2 Replacement - Cheapest Options? - What about Business Smart Hub 2?
Hi all,
I've just moved over from Virgin and I'm pretty upset to find out the BT Smart Hub 2 can't be set up in Modem only mode. What on earth in 2023?
I was using 2, ASUS RT-AX92U AX6100 as a mesh network with the Virgin Hub as the building never works with ISP provided routers.
What's the cheapest way to get a Modem to work with my Asus Routers? I've seen that you can get a BT Business Smart Hub 2 for about £25 which seems pretty decent if it would allow BT to atleast offer some level of support.
I've seen lots of discussions on here, but none that give suggestions out right.
2 REPLIES 2
Message 2 of 3
Re: Modem Mode - Smart Hub 2 Replacement - Cheapest Options? - What about Business Smart Hub 2?
Huawei HG612 from eBay
Message 3 of 3
Of course if you are on FTTP, you don't need a modem, the ONT would connect via ethernet to one of the routers
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
