Message 1 of 2
Move hh6 via home network
I'm having some speed issues with my broadband, losing about 12mbps. My HH is currently under the stairs very close to the main power fuse and consumer unit, it's sitting on my patch panel, the openreach v4 faceplate is also here.
I am thinking of moving the HH to another room by connecting the openreach v4 data port to my patch panel via an rj11 to rj45 cable. Then plugging the HH into a network point using an rj45 to rj11 cable.
Will this work, also I've read the openreach v4 faceplate data socket is actually an rj45, is this correct?
1 REPLY 1
Message 2 of 2
Re: Move hh6 via home network
Should work, easy way to find out.
