Message 1 of 2
Moved over from EE to BT FTTP
I have moved over from EE to BT router FTTP 2. We had 3 smart WIFI discs installed. Tried to setup to BT router but will not connect.
Is there anyway round this or do I need to get BT discs?
1 REPLY 1
Message 2 of 2
Re: Moved over from EE to BT FTTP
Hi
Just wondering if you managed to connect the EE discs
I've moved from EE as well and can't connect the old discs to the BT Smart Hub 2 router either
