@jeeves1 wrote:
All good points. We have given notice but we are with a provider called Boundless which is cloud/microwave signals as we never had fibre available here when the house was built
In that case it will not matter, as they are not using the copper pair.
@jeeves1 wrote:
Sorry if I'm being simple here - do you mean running a CW1308 across the room because it's a thinner cable?
Yes, you don't need an Ethernet cable as all you are doing is extending the incoming 2wire line, not Ethernet. But as @Keith_Beddoe says, you might be able to get the socket moved as part of the install.
