My Mac won't connect to my network, error message saying wifi doesn't have an ip address, it's set to automatically configue but isn't, my phone and tablet are connected, I'm connected through BTwifi with fon at the moment, this connection won't allow me to open home hub
Richard
Solved! Go to Solution.
if you are trying to connect to BTWIFI/FON then you need to use your BTID if you are trying to conenct to your home network then use wifi password if unsure use one of your already home network connected devices to check that you have smart setup turned off and then try connecting MAC to home network again
Thanks very much everyone I'm sorted out now, Apple support fixed it
Hi, I ha e same problem. Do you mind sharing how Apple support fixed it please?
thanks
