Message 1 of 8
My Mac won't connect to my network, error message saying wifi doesn't have an ip address, i
My Mac won't connect to my network, error message saying wifi doesn't have an ip address, it's set to automatically configue but isn't, my phone and tablet are connected,  I'm connected through  BTwifi with fon at the moment, this connection won't allow me to open home hub
Richard
7 REPLIES 7
Message 2 of 8
Re: My Mac won't connect to my network, error message saying wifi doesn't have an ip address, i
Btwifi/fon is not your home network you need sign in with BTID
Message 3 of 8
I don't understand your answer, where am I to sign in with my btid. My network won't connect to my router but it will connect to wifi/fon
Message 4 of 8
if you are trying to connect to BTWIFI/FON then you need to use your BTID  if you are trying to conenct to your home network then use wifi password    if unsure use one of your already home network connected devices to check that you have smart setup turned off and then try connecting MAC to home network again
Message 5 of 8
Where do I find smart setup
Message 6 of 8
Message 7 of 8
Thanks very much everyone I'm sorted out now, Apple support fixed it
Newbie
Message 8 of 8
Hi, I ha e same problem. Do you mind sharing how Apple support fixed it please?
thanks
