Message 1 of 16
My Ping
Hi i was wondering somebody can help me please.
I moved in new place in January and i have mk3 master socket but the face plate is missing does that effect performance?
Im a streamer and gamer but when it comes to ping it goes from 40 to 300 every 30 seconds could that be because of the Ethernet extender plugs? my gaming room upstairs and router down the stairs.
Also my bandwidth goes all over the place. please i really need help.
15 REPLIES 15
h3x1e
Message 2 of 16
Re: My Ping
Take a picture of what your setup looks like, socket wise.
Also it sounds extremely like something a lot of us are experiencing right now, and the number of people posting about it is increasing.
But cant confirm until we rule out everything else.
Message 3 of 16
Re: My Ping
Hi this is a pic of my socket
h3x1e
Message 4 of 16
Re: My Ping
No pic attached, use Gyazo with a link or :Annotation 2019-07-26 093549.jpg
Images need to be 333KB or less btw
Message 5 of 16
Re: My Ping
Message 6 of 16
Re: My Ping
recently ive took filter off as no need for it
h3x1e
Message 7 of 16
Re: My Ping
So correct me if im wrong.
Phone is plugged straight into the Test socket (or is there nothing plugged into it now?)
Router is then plugged into the top RJ1 socket?
Network cable coming from PC to Router?
Message 8 of 16
Re: My Ping
phone connected to test socket.  router is connected to rj1 socket, network cabling,  the router is downstairs, it has 3 Ethernet cables connected to it, i have 1 connected to ps4 downstairs, and 2 connected to 2 Ethernet plug extenders downstairs then i have another 2 Ethernet cables connected to 2 extenders upstairs to pc and ps4 pro.
h3x1e
Message 9 of 16
Re: My Ping
What do you mean by Ethernet Extenders? Just WiFi extenders or a Network Switch? Asking since you said you have 3 Ethernet cables connected to the Router and list 5 Ethernet cables.
Message 10 of 16
Re: My Ping
67168405_355739418677318_4720673961774415872_n.jpg67366412_329406511274699_2830963088260333568_n.jpgimgonline-com-ua-CompressToSize-SKmJgeLxsQ33uU.jpg
both together are the ones connected to the router, the ones with red carpet are the ones in my room.
