Gracie2
Message 11 of 14
Re: My WiFi has not been activated
The phone line engineer fit the hub for me, it is set up as it’s supposed to be
Gracie2
Message 12 of 14
My hub is has a steady orange light
Hello,
an engineer has previously come to install line etc. I have been told my WiFi has been activated, but my hub is a steady orange light. What does this mean? Everything is plugged in properly etc.
what can I do to fix this?
Anonymous
Not applicable
Message 13 of 14
Re: My hub is has a steady orange light
It means you have no internet connection, there's not a lot you can do other than check that everything is plugged in and switched on, you will need to ring them.
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-can-t-connect/what-do-the-ligh...
licquorice
Message 14 of 14
@Gracie2 wrote:
Hello,
An answer to my question in message 8 will help.
