cbrstu
Message 1 of 3
My broadband keeps dropping out
My broadband keeps dropping out its so annoying fed up with it now  modem keeps on restarting when it drops
 21:27:41, 24 May.DSL Link Down: duration was 12 seconds
sun 3 times so far  sat o Friday o Thursday 4 times wed 3 times
random times when it drops
in the last two weeks ive had a new modem which hasn't made any difference new box on wall to a new one
i have also made a complaint to which the women said she wold phone to make sure its working but hasn't
my internet didn't do this before
1:53:36, 24 May.2.4G Client associate from 68:64:4b:37:65:de (IP=192.168.1.201) RSSI=-41, Rate=57Mbps, host
21:53:35, 24 May.Receive a DHCP request
21:32:00, 24 May.CWMP: HDM socket closed successfully.
21:32:00, 24 May.CWMP: HTTP authentication success from pbthdm.x.x.x
21:32:00, 24 May.CWMP: HDM socket opened successfully.
21:32:00, 24 May.CWMP: session completed successfully
21:31:59, 24 May.CWMP: HTTP authentication success from pbthdm.x.x.x
21:31:59, 24 May.CWMP: HDM socket opened successfully.
21:31:58, 24 May.CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
21:31:58, 24 May.CWMP: Session start now, server: https://pbthdm.x.x.x, Event code:
21:31:58, 24 May.CWMP: Initializing transaction for event code 4 VALUE CHANGE
21:31:34, 24 May.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
21:31:31, 24 May.NTP synchronization success
21:31:18, 24 May.WAN Sensing Auto sensing Complete, interface selected
21:31:18, 24 May.WAN Sensing Auto sensing Running
21:31:17, 24 May.WAN Sensing Auto sensing Complete, interface selected
21:31:16, 24 May.WAN IPv6 Global unicast prefix / length: 2a00:23c6:6b0a:f200::/56
21:31:16, 24 May.WAN IPv6 Global unicast address allocated: 2a00:23c6:6b0a:f200::1/64
21:31:16, 24 May.WAN DHCPv6 events: BOUND
21:31:13, 24 May.WAN DHCPv6 events: INIT
21:31:13, 24 May.NTP synchronization start
21:31:12, 24 May.WAN Sensing Auto sensing Running
21:31:12, 24 May.Success - secondary DNS servers
21:31:12, 24 May.Success - primary DNS servers
21:31:12, 24 May.WAN connection WAN2_INTERNET_PTM connected
21:31:11, 24 May.PPP: IPCP up
21:31:11, 24 May.PPP IPCP Receive Configuration ACK
21:31:11, 24 May.PPP IPV6CP Receive Configuration ACK
21:31:11, 24 May.PPP IPCP Send Configuration Request
21:31:11, 24 May.PPP IPCP Receive Configuration NAK
21:31:11, 24 May.PPP IPCP Send Configuration ACK
21:31:11, 24 May.PPP IPCP Receive Configuration Request
21:31:11, 24 May.PPP IPV6CP Send Configuration ACK
21:31:11, 24 May.PPP IPV6CP Receive Configuration Request
21:31:11, 24 May.PPP IPV6CP Send Configuration Request
21:31:11, 24 May.PPP: CHAP authentication succeeded
21:31:11, 24 May.PPP CHAP Receive success : authentication successful
21:31:10, 24 May.PPP CHAP Receive Challenge
21:31:10, 24 May.PPP: LCP up
21:31:10, 24 May.PPP LCP Receive Configuration ACK
21:31:10, 24 May.PPP LCP Send Configuration ACK
21:31:10, 24 May.PPP LCP Receive Configuration Request
21:31:10, 24 May.PPP LCP Send Configuration Request
21:31:10, 24 May.PPP: Received PADS
21:31:10, 24 May.PPP: Sending PADR
21:31:10, 24 May.PPP: Received PADO
21:31:10, 24 May.PPP: Sending PADI
21:31:05, 24 May.PPP: Sending PADI
21:31:00, 24 May.PPP: Sending PADI
21:30:55, 24 May.PPP: Sending PADI
21:30:50, 24 May.PPP: Sending PADI
21:30:45, 24 May.PPP: Sending PADI
21:30:40, 24 May.PPP: Sending PADI
21:30:34, 24 May.PPP: Starting PPP daemon
21:30:34, 24 May.WAN Auto-sensing detected port DSL WAN
21:30:34, 24 May.DSL Link Up: Down Rate=50390kbps, Up Rate=14135kbps; SNR Margin Down=0.0dB, Up=0.0dB
21:27:41, 24 May.PPP: Stopped PPP daemon(0,1,5)
21:27:40, 24 May.PPP: Starting PPP daemon
21:27:39, 24 May.WAN Auto-sensing detected port DSL WAN
21:27:39, 24 May.DSL Link Up: Down Rate=50558kbps, Up Rate=15061kbps; SNR Margin Down=0.0dB, Up=0.0dB
21:24:57, 24 May.DSL Link Down: duration was 6023 seconds
any one able to help with this please admin
regards Stuart
2 REPLIES 2
imjolly
Message 2 of 3
Re: My broadband keeps dropping out
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
cbrstu
Message 3 of 3
hi thanks for the reply 17070 2 fine no noise
BT Smart Hub Manager
undefined
This is a list of your BT Smart Hub settings and current statistics.
Product name:Smart Hub
Serial number:+088044+1749006741
Firmware version:v0.09.06.05093-BT
Firmware updated:Thu Jul 19 17:27:15 2018
Board version:01
DSL uptime:-
Data rate:-
Maximum data rate:14.433 Mbps / 58.659 Mbps
Noise margin:5.5 / 6.1
Line attenuation:22.4 / 18.4
Signal attenuation:22.2 / 18.2
Data sent / received:-
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BTHub6-ZNPZ
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:BTHub6-ZNPZ__5GHz
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:EC:F4:51:B1:12:E9
Software variant:-
Boot loader:0.1.6-BT (Fri Sep 9 10:05:09 2016
i think this is right
