Message 1 of 35
My network is under attack
This has been going on a while.
About 2 weeks ago someone managed to shut down my pc, corrupt my boot sector, destroy a HDD and scrub my event log.
I managed to recover everything, format the drives to GTP, scrub them then reinstall windows 10. SSD survived and all the other components but my HDD is dead.
Bought a full Norton package, went through all my router settings and tightened everything up.
I suspect this attack is a business rival or a disgruntled customer that I had to drop their job at the start of this covid-19 stuff.
11:28:56, 13 Apr.IN: BLOCK [16] Remote administration (TCP [24.212.15.149]:10375-​>[86.171.64.51]:8080 on ppp3)
11:24:17, 13 Apr.IN: BLOCK [16] Remote administration (TCP [91.226.58.44]:18086-​>[86.171.64.51]:8080 on ppp3)
11:23:50, 13 Apr.IN: BLOCK [16] Remote administration (TCP [185.143.221.85]:55982-​>[86.171.64.51]:443 on ppp3)
11:23:30, 13 Apr.IN: BLOCK [16] Remote administration (TCP [62.173.149.190]:53089-​>[86.171.64.51]:80 on ppp3)
11:20:13, 13 Apr.IN: BLOCK [16] Remote administration (TCP [222.142.140.22]:9056-​>[86.171.64.51]:80 on ppp3)
11:18:52, 13 Apr.IN: BLOCK [16] Remote administration (TCP [200.236.117.48]:3840-​>[86.171.64.51]:80 on ppp3)
11:12:16, 13 Apr.IN: BLOCK [16] Remote administration (TCP [178.54.207.101]:49501-​>[86.171.64.51]:22 on ppp3)
11:10:56, 13 Apr.IN: BLOCK [16] Remote administration (TCP [92.118.37.58]:52233-​>[86.171.64.51]:8443 on ppp3)
11:05:34, 13 Apr.IN: BLOCK [16] Remote administration (TCP [207.180.198.112]:46041-​>[86.171.64.51]:22 on ppp3)
11:04:07, 13 Apr.IN: BLOCK [5] Fragmented packet (IP 185.64.189.112-​>86.171.64.51 fragment_offset=2960)
11:00:49, 13 Apr.IN: BLOCK [16] Remote administration (TCP [89.163.153.41]:39601-​>[86.171.64.51]:22 on ppp3)
10:59:50, 13 Apr.IN: BLOCK [16] Remote administration (TCP [165.227.89.114]:37872-​>[86.171.64.51]:22 on ppp3)
10:58:55, 13 Apr.IN: BLOCK [16] Remote administration (UDP [162.243.133.176]:52388-​>[86.171.64.51]:161 on ppp3)
10:53:44, 13 Apr.IN: BLOCK [16] Remote administration (TCP [216.243.31.2]:55535-​>[86.171.64.51]:80 on ppp3)
10:53:20, 13 Apr.IN: BLOCK [16] Remote administration (TCP [45.125.66.204]:48462-​>[86.171.64.51]:80 on ppp3)
10:52:29, 13 Apr.
IN: BLOCK [16] Remote administration (TCP [62.173.149.190]:53123-​>[86.171.64.51]:443 on ppp3)
This is just a current snapshot. The attempts vary between just packets, TCP reset attack and remoate administration. The log changes every time I look at it, stuff is getting scrubbed.
I want to know mainly if I can download my full event log and what can I do?
I have disabled all forms of remote access and everything possible so I am confident they can't damage my pc again. However this is relentless. I have had to limit all my devices to wired connection because if I enable wireless the requests tripple and I become unable to log into the router.
34 REPLIES 34
Message 2 of 35
Re: My network is under attack
from your post are you a business customer?  if so you need to post here as this is residential forum
https://business.forums.bt.com/
Message 3 of 35
No, I am a personal customer. I am a Sole-trader and this is my home network.
Message 4 of 35
If you are trading under a name, then you are a business.
Either way, I suggest you factory reset your BT  hub, which will remove any persistant connections.
I would also suspect that you have open ports on port 80. 443, and 8080, which will make you a target for attacks.
Message 5 of 35
I am a landscape gardener?
I use my network to surf facebook and play Battle.net games, there's not a lot of landscaping you can do via a PC...
Can we focus on the problem I'm suffering on my home network please?
I have no idea why this is going on, just a hunch it could be related to my work.
Factory reset doesn't resolve the attack.
12:53:47, 13 Apr.IN: BLOCK [15] Default policy (TCP [80.82.64.73]:52212-​>[109.149.79.51]:1437 on ppp3)
12:53:46, 13 Apr.IN: BLOCK [15] Default policy (TCP [23.195.126.249]:443-​>[109.149.79.51]:44116 on ppp3)
12:53:46, 13 Apr.BLOCKED 1 more packets (because of Default policy)
12:53:45, 13 Apr.IN: BLOCK [15] Default policy (TCP [23.13.216.186]:443-​>[109.149.79.51]:44616 on ppp3)
12:53:45, 13 Apr.BLOCKED 1 more packets (because of Default policy)
12:53:45, 13 Apr.IN: BLOCK [15] Default policy (TCP [2.17.146.85]:443-​>[109.149.79.51]:41380 on ppp3)
12:53:43, 13 Apr.IN: BLOCK [15] Default policy (TCP [2.17.146.85]:443-​>[109.149.79.51]:41406 on ppp3)
12:53:39, 13 Apr.IN: BLOCK [15] Default policy (TCP [23.195.126.249]:443-​>[109.149.79.51]:44116 on ppp3)
12:53:39, 13 Apr.BLOCKED 3 more packets (because of Default policy)
12:53:39, 13 Apr.IN: BLOCK [15] Default policy (TCP [2.17.146.85]:443-​>[109.149.79.51]:41380 on ppp3)
12:53:39, 13 Apr.BLOCKED 1 more packets (because of Default policy)
12:53:36, 13 Apr.BLOCKED 3 more packets (because of Default policy)
12:53:36, 13 Apr.IN: BLOCK [15] Default policy (TCP [2.17.146.85]:443-​>[109.149.79.51]:41384 on ppp3)
12:53:36, 13 Apr.IN: BLOCK [15] Default policy (TCP [23.195.126.249]:443-​>[109.149.79.51]:44116 on ppp3)
12:53:36, 13 Apr.BLOCKED 10 more packets (because of Default policy)
12:53:36, 13 Apr.IN: BLOCK [15] Default policy (TCP [2.17.146.85]:443-​>[109.149.79.51]:41406 on ppp3)
12:53:36, 13 Apr.BLOCKED 8 more packets (because of Default policy)
12:53:36, 13 Apr.IN: BLOCK [15] Default policy (TCP [23.13.216.186]:443-​>[109.149.79.51]:44616 on ppp3)
12:53:36, 13 Apr.BLOCKED 14 more packets (because of Default policy)
12:53:36, 13 Apr.IN: BLOCK [15] Default policy (TCP [2.17.146.85]:443-​>[109.149.79.51]:41380 on ppp3)
12:53:35, 13 Apr.( 201.890000) WPA2 mode selected
12:53:32, 13 Apr.( 198.570000) WPA2 mode selected
12:53:27, 13 Apr.( 193.200000) CWMP: session completed successfully
12:53:27, 13 Apr.IN: BLOCK [15] Default policy (TCP [135.92.6.73]:443-​>[109.149.79.51]:49508 on ppp3)
12:53:24, 13 Apr.( 190.370000) CWMP: Set Parameter by TR069 Success
12:53:21, 13 Apr.( 187.630000) CWMP: Set Parameter by TR069 Success
12:53:20, 13 Apr.( 186.130000) CWMP: Set Parameter by TR069 failure 9007: Unable to activate 5GHz capability when 2.4GHz is inactive
12:53:18, 13 Apr.( 184.590000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
12:53:13, 13 Apr.BLOCKED 1 more packets (because of Default policy)
12:53:13, 13 Apr.IN: BLOCK [15] Default policy (TCP [185.119.173.53]:443-​>[109.149.79.51]:60453 on ppp3)
12:53:12, 13 Apr.( 179.040000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
12:53:12, 13 Apr.( 179.040000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP'
12:53:12, 13 Apr.( 178.600000) CWMP: session completed successfully
12:53:09, 13 Apr.IN: BLOCK [15] Default policy (TCP [89.248.160.178]:50982-​>[109.149.79.51]:18209 on ppp3)
12:53:08, 13 Apr.( 175.010000) CWMP: Initializing transaction for event code 0 BOOTSTRAP
12:53:08, 13 Apr.( 174.840000) CWMP: Set Parameter by TR069 Success
12:53:07, 13 Apr.( 173.160000) CWMP: HTTP authentication success from https://pbthdmw.bt.mo
12:53:03, 13 Apr.( 169.190000) CWMP: Server URL: https://pbthdmw.bt.mo; Connecting as user: Default username
12:53:03, 13 Apr.( 169.190000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST'
12:53:02, 13 Apr.( 168.760000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
12:53:01, 13 Apr.( 167.420000) CWMP: session completed successfully
12:53:01, 13 Apr.IN: BLOCK [15] Default policy (TCP [135.92.6.74]:443-​>[109.149.79.51]:36156 on ppp3)
12:52:57, 13 Apr.( 163.640000) CWMP: Set Parameter by TR069 Success
12:52:56, 13 Apr.IN: BLOCK [15] Default policy (TCP [1.1.1.1]:443-​>[109.149.79.51]:60467 on ppp3)
12:52:55, 13 Apr.( 161.930000) CWMP: HTTP authentication success from https://pbthdmw.bt.mo
12:52:55, 13 Apr.IN: BLOCK [15] Default policy (TCP [92.118.37.58]:52233-​>[109.149.79.51]:9212 on ppp3)
12:52:51, 13 Apr.IN: BLOCK [15] Default policy (TCP [1.1.1.1]:443-​>[109.149.79.51]:60451 on ppp3)
12:52:48, 13 Apr.( 155.120000) NTP synchronization success!
12:52:46, 13 Apr.( 153.540000) New GUI session from IP 192.168.1.64
12:52:45, 13 Apr.( 152.650000) Admin login successful by 192.168.1.64 on HTTP
12:52:45, 13 Apr.BLOCKED 1 more packets (because of Default policy)
12:52:45, 13 Apr.IN: BLOCK [15] Default policy (TCP [185.156.73.54]:47729-​>[109.149.79.51]:1994 on ppp3)
12:52:42, 13 Apr.( 149.200000) CWMP: Server URL: https://pbthdmw.bt.mo; Connecting as user: Default username
12:52:42, 13 Apr.( 149.190000) CWMP: Session start now. Event code(s): '0 BOOTSTRAP,4 VALUE CHANGE'
12:52:41, 13 Apr.( 148.460000) NTP synchronization start
12:52:40, 13 Apr.( 147.390000) WAN operating mode is VDSL
12:52:39, 13 Apr.( 146.090000) PPP IPCP Receive Configuration ACK
Message 6 of 35
Then you have open ports, probably as a result of playing games, as that exposes your IP address to other users.
The firewall is blocking these attempts anyway, so just ignore the event log.
Message 7 of 35
I disabled all port forwarding, UPnP and UDP settings last night because they were exploring for vulnerability there.
Message 8 of 35
Then you shold see less attempts now. Just ignore the logs, the firewall is doing its job.
Message 9 of 35
Ok thanks.
Will I just have to wait for them to get bored before I can turn on wireless again?
Message 10 of 35
If the firewall is doing its job, have you thought that it could just have been a hard drive failure that corrupted your operating system and ultimately the hard drive failed.
