jgrnfld
Message 1 of 11
My phone is not listed in My Network on Home Hub 5
My Android phone is connected to my BT Home Hub 5 wifi at 5 ghz. When I open the hub in my browser, the phone is not listed as a device. When I connect at 2.4 ghz it is. I don't have a problem with my internet connection but not seeing my phone listed in My Network just irks me. Any thoughts?
10 REPLIES 10
Distinguished Guru
Message 2 of 11
Re: My phone is not listed in My Network on Home Hub 5
Are you sure your phone has 5 ghz capabilities? My older samsung didn't
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
jgrnfld
Message 3 of 11
Yes - my phone (Nexus 5) connects at 5ghz as well as at 2.4 Ghz.
dgw1
Message 4 of 11
Some devices drop connections on 5Ghz. I'm not saying your phone does, but generally I find 2.4Ghz a lot more reliable than 5Ghz.
jgrnfld
Message 5 of 11
It's not dropping the connection, it just isn't showing in the list. If I connect to 2.4, it shows up. If I connect to 5, it doesn't. My wife has the same phone and hers is showing up on the 5 list and she's not even home.
Message 6 of 11
Have you re-freshed the list?
jgrnfld
Message 7 of 11
About a thousand times.
Message 8 of 11
Why do you need to see it?
jgrnfld
Message 9 of 11
Well, just because I should be able to see it. Otherwise, I should just forget about it but I want to find out why it isn't working as it should be.
Message 10 of 11
Try a factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds. If that doesn't work and your phone is connecting OK I would suggest that life is to short to worry about it.
