Message 1 of 4
My wifi disconnected at random intervals
My wifi disconnected randomly using the router from BT. We've tried another router (from my friend) and never lost the connection.
3 REPLIES 3
Message 2 of 4
Re: My wifi disconnected at random intervals
Good morning @southwindy.
Welcome to the BT Community!
When you've been losing WiFi on your BT Hub, are you noticing a change to the lights on the front of here, and are you still able to connect via ethernet when this happens?
Also is the other router you've used also a BT branded one?
Message 3 of 4
I didn’t notice about the light changing because it will reconnect after a few seconds. It happened so randomly, last night I lost the connection 3 times in a row and sometimes once a week.
The other router is from ASUS.
Message 4 of 4
Thanks for confirming that @southwindy.
There's a chance this could be linked with temporary drops in the WiFi connection, but it could be loss of connection to the line itself too; it can be tough to spot this if it's intermittent though.
When you're connected to your BT Hub, have you had a chance to check our fault checker to see if it's highlighting any issues?
If a fault is found linked with your line it will help you arrange an engineer appointment, or otherwise you'll be able to organise a call back from our technical team for further troubleshooting.
Peter
