rob4911
Message 1 of 6
NAS Drive or Media Server for BT Hub 2 Latest May 2020
I would like to set up network storage (NAS) and potential media server (PLEX) attached to new BT Home Hub 2 Latest Release.
Are there any best options or configs that will work best.
Any advice and information greatly appreciated.
Tags (3)
5 REPLIES 5
licquorice
Message 2 of 6
Re: NAS Drive or Media Server for BT Hub 2 Latest May 2020
There are no options or configs you can make.
rob4911
Message 3 of 6
Thanks for the quick reply, does that mean it's not possible to set up NAS from the BT USB ? or it will just work like a dog ?
licquorice
Message 4 of 6
Are you connecting the NAS to an Ethernet port or the USB port? It would be normal to connect a NAS to an Ethernet port. Its not really a NAS per se if you intend to just connect a USB device to the hub.
If you do just intend to connect USB device, it will be extremely slow as the USB port is only USB2 and also you will need to enable SMB1 in your devices
rob4911
Message 5 of 6
Hi There,Thanks for clarifying that, if the fastest option would be to connect the NAS to Ethernet then that's what I will do. Hopefully the speeds there would be decent enough.
Devon_Dave
Distinguished Guru
Message 6 of 6
My NAS plugs into an ethernet port, works fine.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
