katep
Message 1 of 5
Need help with my BT fibre
So as I said need some help I have my hub downstairs so I have a wifi disk from BT in my room which is great but the issue I have is it only has 2 Ethernet connection ports is there a way to add more be it a wi fi disk our a 3rd party solution
4 REPLIES 4
licquorice
Message 2 of 5
Re: Need help with my BT fibre
Just get a cheap unmanaged Ethernet switch with as many ports as you need.
Traynor87
Message 3 of 5
I bought to link switch with 8 ports on yesterday and it works perfectly
katep
Message 4 of 5
Thanks guys have been looking at a Gigabit Ethernet switch but was. It sure it would work with the wifi disk
Traynor87
Message 5 of 5
Yea it works fine. I get max speed now as well like a wired connection
