Showing results forΒ
Search instead forΒ
Did you mean:Β
anthonyUK
Expert
Message 51 of 151
Re: Netflix connection error
Yes, It has worked perfectly since changing the router.
NJP100
Message 52 of 151
Re: Netflix error since joining BT NW-2-5 on JVC tv when trying to watch netflix
Hi just wondering if you have any further news? Thanks
Tags (1)
Message 53 of 151
see message 32 the mods will update the thread as soon as they get more information
MarkPotter
Message 54 of 151
That's great. So BT sent you an HH5 for free?
pieman_42
Newbie
Message 55 of 151
Re: Netflix on PS4
I'm experiencing exactly the same problem. Have searched about online and it seems the problem is something to do with BT parental controls and BT protect
(https://community.bt.com/t5/Connected-Devices-Other/PS4-and-Netflix-woes-BT-DNS-issues/td-p/1421595)
but after disabling them both I'm still unable to get netflix working.
Called BT. Explained what I'd found. The guy on the phone wanted to pass me straight on to netflix but I got him to do some digging. He find a dodgy website that suggested using different DNS numbers but that didn't work.
It seems weird to me that other people have had luck calling BT but someone on the phone can't find out what worked for other customers.
If I figure out how to fix it I'll post on here
iwornmyelbows
Message 56 of 151
There is a similar issue raised over in the Youview topic
anthonyUK
Expert
Message 57 of 151
Re: Netflix on PS4
There are a few threads regarding this already. I suggest closing/merging this one.
There is no solution currently but out of interest please post what router and version you have.
Lloyd
Message 58 of 151
Having exactly the same issue as other users getting error code UI 113 on Samsung Smart TV and BT Youview Box .. Subscribe to Netflix through BT and have Home Hub 3b. Been like this for a few weeks now .. Hope it gets sorted soon as Netflix subscription is a waste if money at the moment 😞
ab79
Message 59 of 151
Re: Netflix - Just stopped working!
I have contacted BT about the issue but got nowhere. Because I have a Netflix subscription not through BT the lady said it's not possible to watch it at all through you view (even though I've been doing just this for over a year now), it just doesn't work she said. Her manager confirmed this.....! Blimey.
She couldn't at all fathom what I was saying about a home hub 3 issue. I may as well have been talking to a brick wall. Because the other channels were working that was that, no problem. It's that simple obviously!
To top it off, I found a contract problem involving my broadband and BT sport re-contracting last summer. My TV contract ends on the 22nd so if I can't watch netflix I will cancel it probably as it (or was) used a lot, Shame.
NJP100
Message 60 of 151
Now LG, who have been helpful albeit without a fix, are becoming about as frustrating as BT. I find it incredible that BT cannot or will not get back with a fix. I had that some years ago when a software update knocked out my toshiba laptop, and after a complete rebuild (at my cost) BT later admitted their update had "effected certain toshiba laptops".
This is exaclty the same and I will be moving from their service ASAP
