redbean
Message 41 of 151
Re: Netflix connection error
I flashed out on a new Router, I didn't want to waste any more of my time. The ASUS seems better than the BT, so far.
And I had already spent money purchasing the Humax to find out it was probably the BT router. Trust it will be resolved soon.
iwornmyelbows
Message 42 of 151
Just to add, it's a Wireless connection and Network Connection Test passes all steps
NJP100
Message 43 of 151
Which model, out of interest?
iwornmyelbows
Message 44 of 151
It's a TX-L32ET5B
DougC
Message 45 of 151
If I was a betting man, which I'm not (I have plenty of other vices), I'd guess that BT have 'enhanced' or at least changed, their internal network throttling of 'dodgy' network activity. Such as downloads by means such as bittorrent. Netflix access will have been collateral damage as they say.
Netflixuser
Message 46 of 151
OP with the latest update.
A new HH5 was sent by BT to replace the HH3 (free as it should have been offered in the first place). Plugged in and connected the TV to the new network and it works. Have come out and gone in several times with no issues, will monitor it over the next couple of days and post another update. No explanation as to why it works just glad it does.
iwornmyelbows
Message 47 of 151
Just contacted BT again but was transferred to the BT TV dept (doh) and gave up.
Does everyone having this problem have a HH3?
MATTHEWH
Message 48 of 151
I've got a HH3 and been having the same issues - been passed from Sony to BT to Netflix back to Sony back to BT etc.......seems like BT is the issue - going to try & get a replacement / free upgrade to a HH4 or 5 - see if that makes a difference
anthonyUK
Expert
Message 49 of 151
I was also using a HH3(b).
I'm using a non-BT router now anyway but the HH5 is meant to be pretty poor judging by reports on here.
I can't accept a router that need frequent factory resets to work correctly.
I went for an ASUS RT-N66U which Amazon warehouse have for approx. £70.
Using open-source Advanced Tomato firmware you know you have 100% control over how your router is configured and the community is very helpful in case of issues.
NJP100
Message 50 of 151
And presumably your Netflix is working fine?
