Telewis
Message 1 of 7
Netgear FVS318N with BT Infinity - Connection Issues
Hi
I'm trying to replace my HH3 with a Netgear Prosafe FVS318N.
Based on research online, I've connected the netgear into the WAN1 port of the modem, configured the netgear to use the bthomehub@btbroadband.com username with no password and set its IP address to 192.168.1.254 but it is failing to connect to BT Infinity. When I replace it with the old HH3 unit, it connects immediately.
Any advice greatfully received.
Tom
Tags (3)
6 REPLIES 6
Message 2 of 7
Re: Netgear FVS318N with BT Infinity - Connection Issues
that device appears to be a firewall not a router
Guru
Guru
Message 3 of 7
Hi @Telewis
Following the command line manual ( http://www.downloads.netgear.com/files/GDC/FVS318N/FVS318N_CLI.pdf )
You need to set up the PPPoE connection. Also try a password such as BT.
Make sure you are setting up a PPPoE connection (as BT Infinity uses this)
isp_connection_type pppoe;
pppoe get_ip_dynamically  y;
pppoe connectivity_type  keepalive;
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Telewis
Message 4 of 7
It is but if it's connecting into the Openreach modem then why is that a problem
Telewis
Message 5 of 7
Thanks. I'll have a play with that but I think there is some form of comlication around using the BT infinity modem and the netgear kit. It see how it goes.
Message 6 of 7
did you try following jac_95 instructions?
Telewis
Message 7 of 7
Hi @jac_95
Very helpful suggestions.
PPPoE certainly worked. I ended up tying to a static IP address and DNS and using the broadbanduser@btbroadband.com user name rather than bthomehub@btbroadband.com
Seems to be working now so many thanks
