Message 1 of 4
Netgear Nighthawk X6 AC 3200 tri-band WiFi Router in place of BT home Hub 5 type A
Hi I have just purchased the above Netgear product, and followed the netgear auto setup process but it will not connect to the internet, had to reconnec
3 REPLIES 3
Message 2 of 4
Re: Netgear Nighthawk X6 AC 3200 tri-band WiFi Router in place of BT home Hub 5 type A
Because its only a wireless router without any modem. If you have ADSL or VDSL you need a combined modem/router unless you already have a separate white openreach modem.
If you do not have a modem, then I suggest you exchange it for a different model which has a DSL input.
Message 3 of 4
Thanks keith, i have a separate openreach modem
Message 4 of 4
Then it should work provided you have entered the correct PPPoE login details.
You can use a user name of broadbanduser@btbroadband.com and a password of bt
MTU Size: no 1492
