atticus88d
Message 1 of 7
Netgear Nighthawk X8 AC5300
Hello!
I have just received a Bit Hub 2 (BT Fibre 2) and the WiFi at the back of the house is pretty bad where I use the iPad for an indoor bike trainer.
I have a Netgear Nighthawk X8 AC5300 WiFi Modem Router and I was wondering:
1) Can I use this instead of the BT Hub 2? If so is it just plug and play?
2) Will it be better?
Thanks!
6 REPLIES 6
licquorice
Message 2 of 7
Re: Netgear Nighthawk X8 AC5300
If it is definitely a VDSL modem/ router and not just a router, then yes, you can use it as a direct replacement. You will need to enter the generic PPPoE username of bthomehub@btbroadband.com and password BT. It will probably be better than the hub, you won't know until you try
licquorice
Message 3 of 7
As I suspected, that device isn't a modem/router, it is just a router and can't be used as a direct replacement for a home hub. You either need to buy a separate modem or use it as an expensive WAP in conjunction with the Hub.
atticus88d
Message 4 of 7
I think it is a modem router. Here is a photo https://photos.app.goo.gl/49d23FH73ejTiPJKA
licquorice
Message 5 of 7
Yep, certainly is. Google let me down. 😀
You're good to go.
atticus88d
Message 6 of 7
Hello! I tried to set this up but I don't have any internet connection. I tried the password both as BT and blank but no go! Any tips?
TimCurtis
Guru
Message 7 of 7
@atticus88d
Are you getting a connection but no access to the internet?
The image maybe cut off on the right hand side but it looks like you've got ".con" instead of ".com" for the username.
