Message 1 of 6
Netgear Wireless N300 Cable Router.
i currently have the home hub 2 but am having issues reagarding online gaming, (nat issues) i have tried every fix that bt helpline has advised me to use but to no avail, my question is if i replace the home hub with the netgear wireless n300 cable router will bt vision and broadband still work, if so what do i have to do to make it work, im guessing it wont just plug in and work?? any help muchly appreciated 🙂
5 REPLIES 5
Peter
Message 2 of 6
Re: Netgear Wireless N300 Cable Router.
We had similar problems with a HH2 and tried every possible setting to correct it but all to no avail.  However, these problems have all been solved since we installed a HH3.  Whilst the Netgear will probably work OK, a HH3 will definitely work with BTV and online gaming but will not support BBtalk.
Message 3 of 6
i have a friend who has a home hub 3 and he has same issues as i do,i have strict nat and he has moderate, which is not much difference, the things that bugs me is we are both on bt but are unable to connect online to play games, hence im reluctent to get a hh3
Message 4 of 6
the cable router will not work on it's own as there is no modem.
Message 5 of 6
any suggestion of a replacement for the home hub 2 that will work with bt broadband but wont have the unfixable nat issues that the home hub 2 has then???
PingMan
Message 6 of 6
Could you not just leave the HH2 running the broadband signal and then connect via cable to the Netgear which could then distribute the wireless signal? Sort of like the RF loop through on a freeview box for example....
