Dstewart92
Newbie
Message 1 of 9
Netgear router/modem won't connect to BT openreach.
Hi,
My previous router was having problems so Im trying to use a Netgear N300 modem router. Although it appears to try connecting, I'm instantly redirected to the Service Information page maintained by BTwholesale.
I've already visited routerlogin.com and ensured that
8 REPLIES 8
Message 2 of 9
Re: Netgear router/modem won't connect to BT openreach.
are you sure the n300 is modem router and not just a router?
Dstewart92
Newbie
Message 3 of 9
Yes, I checked and it's described on the device as a modem router in one.
Message 4 of 9
if you can use quick setup and enter username
bthomehub@btbroadband.com
password if required cab be anything but often just BT will do
Dstewart92
Newbie
Message 5 of 9
I can't seem to do even that. When trying to access any sign in page, as my laptop's troubleshooting recommends, I'm again directed to the Service Information page. Trying to open the Network Login Page via browser does the same. I seem to be completely locked out
Message 6 of 9
reset netgear and start again
I would also initially use an ethernet cable from laptop to router until set up
Dstewart92
Newbie
Message 7 of 9
I'll give an ethernet cable a try and see if that helps then. Thanks. I'll say if there's still a problem
Message 8 of 9
Try setting it up before you connect to the telephone socket.  Just connect the Ethernet cable to the router and your laptop and enter the routers set up pages and enter the BT log on details. Once you have entered and saved the details then plug it into the phone socket.
TimCurtis
Recognised Expert
Message 9 of 9
Are you on ADSL or Fibre broadband?
The only reference I can find for a N300 modem router is the DGN2200 which is ADSL only.
