smint7
Newbie
Message 1 of 3
Network Options
Please could someone tell me why, when I click on "settings" and look for my WiFi options eg "BTHub", "BT WiFi" etc there is also a Virgin Media option available to me?
2 REPLIES 2
Message 2 of 3
Re: Network Options
You will probably be picking up the wireless signal that is being broadcast by one of your neighbours.
Distinguished Guru
Distinguished Guru
Message 3 of 3
Re: Network Options
gg's right. Any wireless-enabled device will detect any wifi signal in range; how would you expect it to select only yours? For what it's worth, I can see at least 9 others in my semi-rural, residential street.
By the same token, anyone else's device will pick up yours. That's why wifi hotspots should always be protected with a password to prevent unwelcome use by others.
