Newbie
Message 1 of 6
Network crashing under stress from downloads.
Our internet keeps crashing during downloads whether it be from Steam/Battlenet or other large file sizes. If the download speed is limited below 1.5mb the crashes are stopped for the most part.
Thanks.
5 REPLIES 5
Message 2 of 6
Re: Network crashing under stress from downloads.
Welcome to this user forum. @TTarpsMail
Please can you confirm which BT Home hub you are using, and whether you have a FTTC connection, or a direct fibre into the house ie FTTP?
Do the lights on the home hub change colour when the network crashes?
Newbie
Message 3 of 6
3.0 and FTTC, the broadband symbol turns red.
Message 4 of 6
So you also have a white Openreach modem as well, does that show a loss of DSL?
The HH3 is quite old now so it may be worth considering upgrading to a newer home hub, and you would also not need the Openreach modem.
Newbie
Message 5 of 6
The Openreach modem does not show a loss of DSL.
Message 6 of 6
Then it just looks like the HH3 is having issues with the throughput.
If this has only recently started, then try a factory reset of the HH3.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
