maybelle
Message 11 of 54
Re: Network did not assign a network address to the computer
Hi Keith - re my previous answer: I managed to overcome my DOS 'query' which was not a query in the end, sorry. My default gateway is indeed 192.168.1.254. On my laptop pc I have no IP address or Subnet Mask, they are both all zero's. I shall try to set up static IP address on my laptop PC as you have advised and hopefully it will do the trick. I shall let you know. Thank you. maybelle
theriddlerz
Message 12 of 54
Keith if u are a res customer of bt remember there is no static ip for res customer and retail will pan u off to biz ness to get 1 and that means new contract and harder to get res account for ur property with any company #justsayin
Message 13 of 54
The static IP that Keith is referring to to is for an internal network setting nothing to do with the dynamic ip address for your internet connection
Message 14 of 54
Indeed, I have all my devices set up with static IP's. Makes it much easier for streaming media/permission of devices!
Message 15 of 54
You are getting confused with the WAN side IP address which is dynamic, and the LAN side which you can change yourself. The home hub handles NAT ( Network Address Translation). Static addressing on the LAN side improves reliability.
Message 16 of 54
You do not need to use DOS, unless you have a very old computer. You can change the network settings from the control panel.
If you have any problems, then tell me which version of Windows you are running.
maybelle
Message 17 of 54
Hi Keith - have all the data from the cdm prompt and ipconfig/all, changed the setting on my laptop as instructed by the instructions you have kindly sent to me, but still no connection has been achieved. Spoke to BT phone help, they are sending me a new router and the Help Agent said that it should then connect. Not sure what router I'll get, my present one is BT HomeHub 1.0. Thank you for your help. maybelle
Message 18 of 54
hi you will most likely get a home hub 3
maybelle
Message 19 of 54
Hi Jonh - will the HomeHub3 enable my WiFi connection to my laptop, would you know? Many thanks. maybelle
Message 20 of 54
yes you should be all right just remember it will have a new wireless security code and you will need to reset all wireless devices you have
