Johnmlowe
Message 1 of 6
New BT user. Wifi a bit disappointing
Recently rejoined BT from Plusnet. Was using Smart Hub router from previous BT account. Worked fine.
Have got new latest edition Smart Hub from BT but noticing that wifi reception doesn't seem as good. Thought this latest hub was supposed to be better than my last on for wifi..
Have always used Powerline Ethernet and Powerline extenders. Still the same, all are connected ok but as I said wifi seems not as good. Slow to connect, or won't connects sometimes.
Any ideas?
Many thanks,
John
5 REPLIES 5
pippincp
Message 2 of 6
Re: New BT user. Wifi a bit disappointing
Have you turned off smart setup as that can affect it.
Johnmlowe
Message 3 of 6
Thanks for your reply.
Yes I have switched that off.
John
imjolly
Message 4 of 6
Have you selected the wireless channels manually instead of auto probably use a WiFi analyser on phone to see channels in use and select a free or less congested channel
Johnmlowe
Message 5 of 6
No, I will give that a go.
Thanks,
John
Stu_H
Message 6 of 6
When you use a WiFi analyser take into account it’s not always going to show all connections. Clients don’t tend to have the range of a router so it gives a rough idea.
Also take into account many use Auto so channels change through the day as well as other environment factors.
if I use say my MacBook it will show around 8 but if I use my routers scan I can see 37 and in a week a total of 90. Not all will cause interference and most are aimed at 2.4.
