newja
Message 1 of 6
New Fibre Smarthub6 - connecting a webcam to 2.4 Ghz
Hi, today I have had my Fibre instal and all is going well in many areas but there are a couple of things not working out right so I shall post 2 separate questions.
I have a webcam that I easily set up on my HH4 once I knew how to create 2 x SSIDs dor 2.4 and 5 ghz.
I replicated my actions on my Smarthub6 and now have 2 SSIDs named appropriately with my android phone connected to the 2.4 side - as I had done previously.
Resetting my camera and using my android phone to effect a connection simply does not work - I am certain that I am connecting (or trying to) to the correct SSID which is the 2.4 ghz one and that I have the correct password.  Now tried several times over the past few hours and reset both the hub and the camera too to no avail.
Various internet searches tell of the importance to split the SSIDs out and yet nothing effects a connection.  (The camera is IPC365 but it seems a common issue with webcams and baby monitors that for most people are solved by splitting their router into 2 SSIDs, one for each band....any ideas please?  TIAbthub.png
Tags (3)
5 REPLIES 5
imjolly
Message 2 of 6
Re: New Fibre Smarthub6 - connecting a webcam to 2.4 Ghz
As it is hh6 have you turned off smart setup?
newja
Message 3 of 6
OK, so I have turned off "smart setup", saved and retried both issues twice - no joy, thanks anyway!
I still am not clear on what smart set up does so have popped it back on again and will research further, thanks anyway...
licquorice
Message 4 of 6
Smart set up tries to launch a browser on a device when it first connects. Devices that don't have browsers get confused, smart set up is definitely best turned off.
From other posts, some devices don't like anything other than alpha or numeric characters inthe SSID. Might be worth changing the SSID to something very simple.
newja
Message 5 of 6
Hmmm, I can try - but the HH4 was the same SSID style and charachters.....will report back
newja
Message 6 of 6
Nice idea but no joy - thanks 🙂
