redrover
Message 1 of 21
New HUB 3 user
Just got connected last Friday
Have my home wifi but NO fon or openreach
what has gone wrong
TVMIA
John
..John
20 REPLIES 20
Message 2 of 21
Re: New HUB 3 user
You should be opted in automatically, but you can check on this link.
BT FON/Wifi  home page, where you can check if your details are correct
Distinguished Guru
Message 3 of 21
Re: New HUB 3 user
BTFon and BTOpenzone (not openreach;)) have been changed to BTWifi and BTWifi-with-fon
Do you see these?
If not, it is unusual as all new hubs, regardless to being opted in or out of BTWifi will always default to transmitting the SSID's. Then depending on whether you're in or out, the hub will reflect this after about 48 hours (possibly even up to 2 weeks).
-+-No longer a forum member-+-
redrover
Message 4 of 21
Re: New HUB 3 user
going round in circles
still no fon signed in for it at least 10 times
and get the message below
BT broadband option:BT Total Broadband Option 1
BT Wi-fi community status:Opted In
 Unlimited
..John
redrover
Message 5 of 21
Re: New HUB 3 user
no sign i'am afraid
..John
Message 6 of 21
Re: New HUB 3 user
Is it that you can't see BT Wifi or fon or that you can't get logged in. To log in you need to use your primary email address as your log on name and your BT Yahoo password. Both are case sensitive.
Distinguished Guru
Message 7 of 21
Re: New HUB 3 user
If you've no user changes to the hub, you could try and force it to start transmitting these SSID's.
There is a little red recessed button on the rear of the hub, press this (with a paper clip or similar) for 20 seconds or until the hub lights go off. Release the button, allow the hub to fully boot (3 blue lights) and then see if it shows them.
redrover
Message 8 of 21
Re: New HUB 3 user
I can log in. I just cant see on my phone or tab the other 2 signal options
..John
Distinguished Guru
Message 9 of 21
Re: New HUB 3 user
So to confirm - if you scan for wireless networks on both devices, BTFon/BTOpenzone/BTWifi/BTWifi-with-Fon are not there in the list of available networks?
Message 10 of 21
Re: New HUB 3 user
Download the BT Wifi App. It's available on both Android and Iphone. It will find and log you in easily.
