Message 1 of 4
New Hub2 and disc
We have signed up to Hub2 and disc (halo3) in the hope it will improve broadband around the house - so far it is worse. When using the BT app to check the wifi speed on the hub or the disc they both come back poor even when you are standing right next to them - is that right? -  are we doing something wrong - BT help line says the disc should be next to the hub as the hub does not broadcast the wifi the disc does- is that correct? So far very frustrating
Tags (2)
3 REPLIES 3
Message 2 of 4
Re: New Hub2 and disc
The disc needs to be paired with the SH2 using the MyBT app
Message 3 of 4
Have a look at this clip which may help you.
BT Support - How to set up Complete Wi-Fi - YouTube
Message 4 of 4
Hi @Karen10   If you are using the Android My BT App then if it is like mine, the WiFi signal strength is broken on 8.29.4.
Same spot:
iPhone 13 Pro - signal strength Strong
Tab S8 Ultra - so bad, asks you to use the troubleshooter
