boggo
Newbie
Message 1 of 3
New NowTV Box and wireless connection to HomeHub
Hi
I have just purchased a Now TV box to use on one of our TVs. It connects fine to an O2 wireless broadband that we have in the house (for work), although the signal is weak,  but will not connect to the wireless on BT HomeHub. Ther are no problems with the HH and the wireless signal is strong. I have run thorugh the diagnostics on the Now TV box with Now TV and all is fine. Can anybody suggest a soultion to the problem?
2 REPLIES 2
Message 2 of 3
Re: New NowTV Box and wireless connection to HomeHub
Change the wireless encryption on the home hub, to WPA only, and see if it helps.
If the TV unit has old settings saved, then delete them and start again, as the IP subnet is different on the home hubs.
boggo
Newbie
Message 3 of 3
Thanks Keith, I'll give that a try.
