Message 1 of 3
New Setup Network Status 'Public Network'
Broadband smarthub setups using 'Public Network' where I have security restrictions. How do I change it to set up in 'Private Network' instead? Doesn't let me change it.  This was not the problem on previous ISP
2 REPLIES 2
Message 2 of 3
Re: New Setup Network Status 'Public Network'
Message 3 of 3
Re: New Setup Network Status 'Public Network' SORTED!
Thanks for your help. Although none of the advice given resolved my problem directly, it did identify that I had an issue with a Critical Update in BIOS which had become considerably outdated. So not a BT issue.
Fortunately I had maintenance cover and got technical support to update and flash the BIOS, as I couldn't perform this process via Windows Update.
So indirectly, each one helped by process of elimination. All sorted!
Cheers ALL!
