imjolly
Message 11 of 26
Re: New Smart Hub vs Old?
I find the SH2 has better wifi range than previous hub but if your happy with existing setup then just stick with it   with the SH2 you cannot split the networks as with previous hubs which may cause a problem with some of your devices although saying that I did not find any device problems
dgravy
Message 12 of 26
Thanks guys. So do I understand correctly the answer to my question is not the smart hub (technically the smart hub 6?) had not changed in hardware, software over its life?
imjolly
Message 13 of 26
they SH1(hh6) is different to SH2 in that you now cannot split the networks like before  the firmware is different but as I said if your existing setup is working ok then just leave it - if it's not broke don't fix it
dgravy
Message 14 of 26
Very sorry I’m not making myself clear, Not withstanding  your advice which I have understood - is the current Smarthub still the smart hub 6 and if so has the Smart Hub 6 changed since first release?
licquorice
Message 15 of 26
There is a HH6 also known as a Smart Hub1 and also a Smart Hub2 which is not the same as the HH6.  Just try the new one and if you don't like it go back to the old one.
dgravy
Message 16 of 26
Thanks. My question are the hh6 the same or did they change over time?
imjolly
Message 17 of 26
The hh6/ SH1 are basically the same whereas the SH2 is different  particularly in that you now cannot split wifi networks
Firmware different but BT do not publicise the changes
dgravy
Message 18 of 26
So.. just to check, the HH6/SH1 is this:
And the SH2 is this?
imjolly
Message 19 of 26
Yes - the SH2 now has the new BT logo
dgravy
Message 20 of 26
And the SH1 didn't change over time?
(Sorry this has been a bit of an exercise in internet misunderstanding 😕)
