Ktf
Message 1 of 11
New build NTE outside
Hi, house about 15 years old and has grey NTE outside on front wall but I cannot find where it connects to inside the house, surely it would be close by, in the hall? I assume it looks like a normal socket? Can anyone help please?
10 REPLIES 10
imjolly
Message 2 of 11
Re: New build NTE outside
As a plusnet user you need to post on plusnet forum
licquorice
Message 3 of 11
Perhaps the previous occupiers didn't have a phone/ broadband service. Can you not ask them if they did where the socket is located. Is there internal cable as well as external in the box
Ktf
Message 4 of 11
Unfortunately can’t ask them as the previous owner has disappeared! There is an extension cable running from the grey outer box along the outside wall and through into the living room but the socket is not attached to it, just a few wires, there is another socket in the same room on an internal wall but none of them seem to be a master socket, also found a couple more upstairs but the neighbours said the previous owner just used his mob phone. I don’t understand how it works as when I look it up everyone seems to have a socket close by. Does this mean it was never connected other than an extension? Thanks
imjolly
Message 5 of 11
originally the grey box was the master socket and all others were just extension sockets. However it did not work with broadband so grey box was rewired and a master socket connected inside home
licquorice
Message 6 of 11
The grey box isn't an NTE, its just a junction box where the external cable is normally connected to the internal cable.
imjolly
Message 7 of 11
grey box like this
Ktf
Message 8 of 11
So one of the internal sockets should be a master socket, they all appear the same to me, sorry if it’s a silly question but how can I tell which one?
Ktf
Message 9 of 11
Ktf
Message 10 of 11
It’s similar but slightly flatter? I walked around the area and everyone else seems to have a smaller type so I don’t know if it was exchanged.
