yellow160
Message 181 of 325
Re: New firmware kills VPN
Hi Neil
I would also like to contact you regarding this issue but can see no "contact the mods link".
John
Message 182 of 325
The link is only available if the moderators opens it for you.
Moderator
Moderator
Message 183 of 325
Hi yellow160,
Click on my username and you'll see the link under my "about me" section.
All the best,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Message 184 of 325
WOOOOHOOOOOOO!!!!
Got a call from BT to say they had a fix and I was going to get a firmware update....
It arrived, and VPN works again! Connected for 10 minutes now without a hitch.
Hang fire on the complaints... all is not lost... help is on its way!!!!
Thanks to all involved in getting this sorted!
Rob
rockmill
Message 185 of 325
Ditto - had an email from BT support saying that a fix would be pushed out to my home hub tonight. However, I think they pushed it out around 4pm and my VPN connection is now working again!!!!
Well done everybody in this thread for complaining and getting BT to fix the problem.
Moderator
Moderator
Message 186 of 325
Hi everyone,
Many thanks for your patience with regards to this matter whilst we have been investigating further.
If you are experiencing this issue, flag on this thread and a mod will be in touch. When you have been contacted by a mod they will need the phone number that your broadband is on and your hub serial number (have a look on the sticker on the base of your hub, something like +058720+1116085830) and we'll apply a work around to your hub over night.
Please note this will result in any user config being lost , so any port forwarding settings or changed SSID’s and Wi-Fi passwords, so you will need to change your settings after the update.
All the best,
Robbie
Kudos”Kudos”
Husky2468
Message 187 of 325
Hi RobbieMac,
I think this problem may be at the root of my Vodafone Suresignal having stopped working, which I've been battling with for the past week - I'd be grateful to the update.
Many thanks...
Moderator
Moderator
Message 188 of 325
No probs Husky2468,
Click on my username and you'll see the link to get in touch under the section "about me" Smiley Very Happy
All the best,
Robbie
Kudos”Kudos”
Stevetipton
Message 189 of 325
Will there be a general push out within the next few days? I for one can wait that long as it will not affect me until Tuesday.
Liam_Holmes
Message 190 of 325
Could I get the update pushed out too please. I'm unable to connect to Xbox or PSN since the Firmware update.
