Astone21
Newbie
Message 1 of 2
New router setup
I'm waiting for a new smart hub to be delivered as my current one has died, just wondering if anyone knows if I set the ssid & password to the same as the old hub, will everything reconnect without me having to re-enter log in details? Have lots of smart devices and stuff so hoping I can avoid setting them all up again would be much easier to just login into hub settings and change router settings.
1 REPLY 1
Message 2 of 2
Re: New router setup
Yep, just change them to be the same as the old hub. The only problem if it is the smart hub2, you can't split the wireless bands.
